ldv5379320's avatar
ldv5379320
LED light strip problem
I purchased  EXCELFU LED light kit from Amazon. I already had a light strip that was connected to the exterior porch light that had failed. After installing the lights to the porch light  they didnt come on. I installed the cigarette lighter portion and connected to my truck lighter, worked fine. I connected the wire connections to a 12v battery, worked fine. Checked the voltage at the outside porch light, 13.49 volts. connected again, nothing. Any suggestions?
  • My guess is the porch light is mis-wired from the factory with the positive and negatives wires reversed. LED's will only work if wired correctly. Whereas an old school incandescent will work even when wired backwards.
  • I never figured out why it wouldn't work through the porch light but I had installed underglow to a switch off of the trailer's battery. I just ran the lights to this switch and it worked perfect!!
  • try posting it in the aproperate section of the board like technical issues and not the comunity feed back.  this section is for issues with the board itself .
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 29, 2026
