rogerramjet442's avatar
Apr 15, 2019
led lights
mine are in a Columbus 5th wheel and are round flat, one is out how do i remove light or cover to replace/ fix ?
  • It may have a notch in the cover so try to rotate it and see if it drops down OR some just unscrew. Once you get the cover off then screws hold it to the ceiling. You will likely have to replace the fixture. They run about $15.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
