Wo_ody
Dec 11, 2015Explorer
LiFePo4 - what components required?
Premise: certainly solar is fine but most of my camping is in the shade or in low solar areas so no solar. And there are more no solar reasons too.
Intent is to have a battery bank of 4S-8P CALB LiFEPO4 batteries. Using 100 amp cells would give me +/- 600 amps of usable 12V nominal power. When available, a 110 AC land line would be used to power the Truck Camper as well as charge the batteries. When not AC connected, the batteries would be charged by 2nd engine alternator (+/-200 amp) dedicated only to battery charging. And a third option would be to charge the batteries using something like a Honda EU2000i portable generator plugged into the AC.
LiFEPO4 require a battery balancing system which most "normal" inverter/chargers do not provide. Not being "Edison minded" I'm trying to wrap my head around the electrical components necessary to make this work as well as the 2D architecture or flow chart of the AC power circuit and the intergration of the alternator power circuit. Simply put, what goes where?
Also, if you are experienced with LiFEPO4, please recommend specific products or vendors where items could be purchased or a design/install house who could provide such a system.
Thanks for your response.
