SFVdave
Dec 28, 2018Explorer
Well, I called BB Batteries and they said not to worry as their batteries come with the BMS that will only let the batteries charge within the proper temperature range... Their batteries will not accept a charge below 25 degrees F and will not discharge below -5 degrees F. Also, their batteries will not over charge. That was per BB Batteries tech. So no need for me to be concerned in Yosemite, I just need to try and get the batteries back up in to charging temperature range should the temperature drop below 25 degrees F.
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 25, 2025
