mike-s
Mar 11, 2018Explorer II
For ST tires, there are load/pressure tables to follow. It's not just inflating to max sidewall pressure. And, those tables apply for the standard 65 mph speed rating. But, ST tires can be run faster - add 10 psi (but not over max, so the effect may be to derate the load) and you're good to 75 mph. Also derate the load by 10% and you can go to 85 mph. That's for all of 'em - specs from the TRA Year Book, the industry "bible."
Manufacturers are able to exceed the standard ratings, so there are tires out there with higher speed ratings at the standard load/inflation. If load range C will handle your load, so will LR-D at the same pressure. But if you're near the max load for an LR-C, a LR-D will let you add 10 psi and increase the speed rating.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
