Iceworm
Feb 29, 2020Explorer
Locating trailer hot wire underhood source 2017 GM
I am looking for the hot trailer wire source under the hood of my 2017 GM Sierra 3500. It is always hot at the trailer plugin. I would like to run the power wire via a constant duty solenoid powered by the ignition. That way it will only be hot when the key is on to prevent my truck battery from running down when using the camper batteries. It was easy to do on my older trucks prior to 2016 but the new ones.....not so much! Anyone done this on the newer GM's? Thanks
