KenS999's avatar
KenS999
Location of Propane Supply Manifold on Wolf Pup?
Hello,
I recently purchased a used 2017 Forest River Cherokee Wolf Pup 16FQ. Does anyone know where I can gain access to the propane supply manifold? I would like to run a dedicated low pressure supply line to inside the living area to supply a portable catalytic heater for boondocking. Does the manifold typically have spare additional unused ports to accomplish this?
Thank you,
Ken
  • Out the window, if you keep it cracked. Otherwise you could have a bad day. Window, roof vent, if you have one. CO and LP detector is also a good idea.
    thanks,
    Ken
  • great advice,question are these type of heaters safe? wheres all the carbonmonoxide go?
  • Follow the propane line from LP Reg.....
    No there are NOT spare ports
    'T' is added for each run from main line to component
    You would need to add a line with 'T'----might be easiest at stove top/or furnace as there are in kitchen area
    You would have to disconnect one of those supply lines.add a nipple and 'T' then connect both supply lines
    Use pipe dope or Yellow Teflon Tape on threaded fittings....none on flared type
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 27, 2025
