- midnightsadieExplorer III,ve have tow masters on my boat trailers worked fine ,these are 3500# boats.one one tires are 8yrs old.
- LwiddisExplorer IIBrand makes little difference IMO. Correct pressure, age, UV protection when not towing, proper load range, speed, road surface etc. are more important.
- wopachopExplorerThe website says 15' wheels need a spec of 3100lbs or higher. Darn i checked and mine are rated at 2800lbs.
I just wrote the company with that info. Hoping the come back saying its something i can try at my own risk.
Does it have to do with holding the higher PSI?
Want to switch to metal valve stems regardless. If anyone has advice on picking out good valve stems im all ears.
Thanks! - 2oldmanExplorer III see some posts on these in 5ers, TTs.. etc. Not here.
- LwiddisExplorer II“Hoping the come back saying its something i can try at my own risk.“
Why would any careful business person advise you to try exceeding max rim air pressure...your risk or not? - TOW-MASTER ASC goes to LRF and 95 psi if the wheels are rated for it.
https://www.greenball.com/brands/greenball/tow-master-asc
Also carry aluminum or steel wheels for the full rating. - Cummins12V98Explorer IIIChinese Made ****, spend your money wisely with the GY ENDURANCE.
- wopachopExplorerHey thanks will check those out!!!
- EsacnjExplorerTerrible tires. I had a blowout start of 3rd season do to belt shift. Often referred to as Blowmaster on the forums.
- wopachopExplorerBlow master comes in many models. Their premium tire is called the ASC.
I'm leaning towards the goodyear's now. Price is so similar I just want the best 15" tire I can get.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
