CT_WANDERER's avatar
CT_WANDERER
LP Water Heater Updated Information
I took my water heater LP system out needed a cleaning, also would not always fire off. I cleaned and adjusted the spark igniter. Put it all back together. Fires right off, the flame is blue just past the burner. A little ways out it turns yellow. Is this a good flame or do I need to adjust the air mix? If so do I give it more air or less? When I had the access door open I had a lot more of a blue flame. When I closed the door I can see what looks like more of a yellow flame. Any help, I would be thank full for. Gary
  • I adjusted the air mix today. Have a great flame and lights off every time I tried it, Thanks to all that helped. Gary
  • Thanks Old-Biscuit that is what I was looking for. Guess I will open the air a little more. Thanks to all that posted for you help and time. Gary
  • The main burner flame should be mainly blue with a trace of yellow and fairly quiet.
    Closing air shutter........results in more yellow/lazy flame (fuel rich--air lean)
    Opening air shutter........results in more blue/strong flame (fuel lean--air rich)
    Door open allows more air to burner area directly vs being pulled thru air shutter.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 22, 2025
