Mmtbpz
Jan 31, 2018Explorer
Magne tek xonverter replacement
New to rving and this forum..wondering if someone can shed some light on my magnetek 6300 converter replacement..im looking to replace the converter portion with a deck mount progressive dynamic 9260 type charger xonverter..on the 12 volt side there are 2 connections. 1 white and 1 red..my magnetec has 3 ..an additional blue..read somewhere that this blue wire needs to be jumpered at the dc fuse panel to the red lead so as to supply filtered power to the entire fuse panel...can someone verify this is the proper way to install this type of new converter or send me in the correct direction if im totally off base in trying to install this converter this way.
Thx in adv
Peter
Thx in adv
Peter
