Itinerant1
Jan 03, 2019Explorer
It's not switching it's load sharing. On the me-arc you set the amount of amp that you want to use from the ac source (generator, power pole). If you're hooked to a plug in source of 15a you set the incoming ac to 15a so any demand above that it will be used from the batteries. Now if your load is 15a or less the inverter will just automatically pass the power through until a larger demand requires extra from the batteries.
