โMay-26-2013 04:17 PM
โNov-27-2013 08:20 AM
Unyalli wrote:Thanks for the link.
Here is a good thread on a 4024 in actual use.
http://busnut.com/forum/index.php?topic=1437.0
Jeff
โNov-27-2013 06:57 AM
โAug-01-2013 08:24 PM
MEXICOWANDERER wrote:If I were to guess it would be Magnum but Victron has a great rep though especially with the marine crowd.
Which brand has the highest percentage of satisfied customers?
I tortured my Trace 4024 and started a 7-1/2 horsepower compressor with it. The unit laughed it off.
smkettner wrote:Totally forgot about the Phoenix line AND they have a 12V 3000VA (2500W @ 25C) inverter too.
Victron does. Note the Phoenix diagram shows a separate charger.
http://www.victronenergy.com/upload/documents/Datasheet%20-%20Phoenix%20Inverter%201200VA%20-%205000...
Can be paralleled to create about any size needed.
โAug-01-2013 11:45 AM
MEXICOWANDERER wrote:Actually we (ex trace guys) are still here, we now go by Magnum.
โAug-01-2013 11:33 AM
mlts22 wrote:
That would completely get rid of the need for an autoformer, and a low-voltage EMS. If I had the cash, that definitely would earn a place in my rig, even if it functioned as a quick and dirty UPS, or if I'm using a marginal generator like a 3000 watt generator, it would absorb the locked rotor amperage without overloading the generator.
โAug-01-2013 11:15 AM
โAug-01-2013 11:08 AM
โAug-01-2013 10:55 AM
pianotuna wrote:
Hi,
I wish Victron had a straight inverter rather than inverter chargers.
โAug-01-2013 10:27 AM
2oldman wrote:True, Samlex/Go Power makes 12V 3000W continuous units. And they're big, heavy inverters too.
Samlex might work at 3k.
โAug-01-2013 10:03 AM
pianotuna wrote:Samlex might work at 3k.
In an ideal world I'd go with 3600 watts (or 4000) but no one makes a 12 volt in that size (a reliable one, that is).
โAug-01-2013 09:46 AM
โAug-01-2013 09:22 AM
โAug-01-2013 08:30 AM
RoyB wrote:
Don - what happened - You get a big contract for tuning up piano's recently hehe.
Roy ken
โAug-01-2013 07:56 AM
pianotuna wrote:All very good points.
Hi Jeff,
That's an unfair comparison--but my ideal inverter would be PSW, stand alone, 12 volt and 3600 watts continuous.
I could start with one Victron and add a second one if need be. Magnum doesn't offer that feature. Don't get me wrong, I believe the Magnum is a great unit.
The Victron Quattro can be connected to dual 120 volt power sources. "More Power
Two AC inputs with integrated transfer switch. The Quattro can be connected to two independent AC sources, for example shore-side power and a generator, or two generators. The Quattro will automatically connect to the active source. "
