BFL13
Apr 02, 2018Explorer II
With a monitor like a Trimetric that only shows the amps to the battery, not the other amps, there would be no problem here.
The OP's problem is that his Magnum monitor (or display) seems shows all the amps it makes. Similar to a solar controller's output amps--not all go to the battery. (The Kidd whizbang is supposed to separate those if fitted, but with the shared shunt, it could be getting mixed up --I suspect the installation of all that is "problematic". )
Having RV issues? Connect with others who have been in your shoes.24,217 PostsLatest Activity: Mar 17, 2025
