maximum dc voltage output Magnum 3012 with remote
pianotuna
Nomad III
Nomad III
Hi,
I was toying with my charge voltages. I wanted to try 15.4. When I set 15.4 on the remote it did not get above 14.7 volts. The bank was fairly full so it was only doing between 8 and 10 amps of charging.
Does anyone know the maximum dc output voltage?
Regards, Don
24 REPLIES 24
pianotuna
Nomad III
Nomad III
First reply is to use the setup menu to adjust the float voltage. I wrote back and told them I had already done that.
Regards, Don
pianotuna
Nomad III
Nomad III
I've just emailed Magnum and will report back what they say.
Regards, Don
time2roll
I think the idea is to try something different. Otherwise best to contact Magnum.
pianotuna
Nomad III
Nomad III
Just tried this again.
At 15.4 set on remote I got a maximum voltage of 14.8 at the battery terminals. Amps were 8.0. It is 11.7 c (53.1 f). I ran the test for 10 minutes. When I "backed off" to a float of 13.2, charging went to 13.5 volts @ 0 amps. After another ten minutes that went to 13.5 @ 8 amps.
Regards, Don
MEXICOWANDERER
This...
Is ALWAYS more intelligent than this
Installing a menu root that offers totally manual control frightens some people ""If It Is Available A Troglodyte Will Use It Then Run To An Ambulance Chaser""
pianotuna
Nomad III
Nomad III
time2roll,
They were only charging at 9 amps.
I'm using the "custom" setting on the remote.
Regards, Don
time2roll
Try 14.9 next time you run them down a bit. Is there a second limitation by battery type etc? Maybe reduce the amp rating to 50% of max.
MySuncoastRV
If your battery is at or near charge capacity of 14v, your voltage will be regulated down from 15.4volts. If your battery was sitting at a lower capacity such as 10volts when you would see higher charging output voltage. This can usually be confirmed by using a volt meter while briefly disconnecting the positive lead from the charging source simulating a fully discharged battery. This would command 15.4v max charge. Running the charger like this for an extended time could cause damage.
pianotuna
Nomad III
Nomad III
Hi,
The banks were at 19.5 C, so I think it is not temperature related.
Regards, Don
Chris_Bryant
It may have been limiting due to temperature. I know those will do well over that voltage for equalization.
-- Chris Bryant
