path1
Sep 19, 2015Explorer
Messed up and need some wisdom about Torquing
I messed up, like nobody has ever done before, right? Looking for little bit of wisdom.
It was time to adjust my transmission bands. I drained the fluid and removed pan. I went to go get my inch pound torque wrench, and can’t find it. Last time I used it was in Yuma. I think it's in the shed there, and doesn’t help me because I’m at my home base in WA state. I messed up even more by parking behind my other car. So I can’t just hop in car and get another wrench. Neighbor on one side is gone for weekend. Neighbor on other side…Well good fences make good neighbors.
Here is plan “B”. Please don’t laugh. I think this will work as I’m creating measured force (torque). But don't want to mess up trans or re-do project again.
I need 72 inch lbs. So I'll fill up empty gallon milk jug till I get 6 pounds on a pretty good scale that I have. Put box end of wrench on the bolt I need torqued at right angles and connect other end of wrench to milk jug (with string or something). I would then be at right angles, and gently let the weight of 6 pounds put pressure on bolt.
I realize this is mickey mouse but I would prefer not putting pan back on and trans fluid back in, if possible just to go get another torque wrench.
Do you think this is going to end well?
