DR650's avatar
DR650
Modifying CARB compliant Honda gas caps (extended run system
Has anyone modified the CARB compliant Honda gas caps when making an extended run fuel system? I have the large diameter caps that click when they're fully tightened on the generator. The CARB compliant caps are two piece and rattle when the generators are running, I would like to modify those caps and keep the new (old style) caps that I ordered from Amazon when I use the gens without the extended run tank. Will the CARB caps be airtight after the modification assuming I do a good job of installing the gas fitting and sealing it with JB weld?
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 09, 2025
