mlts22's avatar
mlts22
Dec 22, 2014
Multiple inverters?
Would it help with maximizing battery power if one had multiple inverters for their rig?
One would be a 300 watt PSW like the Morningstar SureSine 300. This would be hooked up to an outlet or two and used for low-draw stuff, be it an electric razor, charging cordless power tool batteries, or other items.
Another would be a 2000 watt PSW inverter whose job would be to handle appliances like a Keurig coffee maker or other appliances which use a lot of juice, but have a relatively short duty cycle.
The advantage of having both is that the smaller inverter can always remain on (well, assuming it is being used), so its power overhead is a lot less. The larger one can be turned on/off when needed, as it has a larger (think 200 watts) overhead.
Think this would be a good way to go to maximize battery life when boondocking?
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
