lem55's avatar
lem55
New to lithium battery
Have a question which l hope you can help with. First my charge/converter went out and replaced with a 40 amp OEM unit. I know this unit is not designed to charge the lithium battery.
I needed to replace my batteries, so I invested in a 200 amp lithium
battery with a external charger designed to charge it.
And now for the question, will it hurt the lithium battery to be hooked
to the system when I am plugged into shore power. a long with that I have a old 100 watt solar charging system. Do I need to put in a disconnect switch. I had planned on charging with lithium charger.
I don't want to damage this very pricey battery.
Please help.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
