- _1FlyboyExplorerwnjj…. I used your suggestion and… yep…. It’s the switch… Got a new switch ordered from Amazon… Thanks wnjj & everyone else that helped!!!
- This is probably the best water heater troubleshooting video I've seen.
Diagnosing a Suburban RV Water Heater AC and DC Electrical
He's a mobile RV repair tech and has a lot of really good videos on his channel - wnjjExplorer II
enblethen wrote:
Your Honda genset has a floating neutral. Your reading between element and frame can be missing leading. For my inverter genset, I made a plug cheater that ties the neutral and ground together. It is inserted into the duplex receptacle.
Great point.
When measuring AC voltages around the water heater, use the other pin on the element as the neutral (the one not connected to the relay/switch/limit switch). - Your Honda genset has a floating neutral. Your reading between element and frame can be missing leading. For my inverter genset, I made a plug cheater that ties the neutral and ground together. It is inserted into the duplex receptacle.
- pianotunaNomad IIIHi,
I thought my element had failed. I bought a new one. After replacement, the new one started to work. I guess the relay had frozen "open" and the act of replacing the element "fixed" it. - _1FlyboyExplorerrnblethen… that was the first step, thanks for sharing….
- Do all the 120-volt receptacles and appliances work?
If they work, try this. Water heater is normally on its own breaker. Try resetting the breaker. Turn it off applying light pressure toward off then turn it on. - _1FlyboyExplorerWnjj… I’ll try your suggestion when I get time, on the road for a while and propane heater works fine… thank you….
- wnjjExplorer II
enblethen wrote:
Manual. Manual
Yes, there is relay
This is helpful. Look at figure 7 for the AC wiring. The 120V power from the breaker panel connects to the relay. Then when 12VDC is applied to the coil (refer to figure 6), the relay should pass the 120V to the switch. Then once the switch is on, it feeds the hi-limit cutout and finally to the element itself.
If you're comfortable checking with power on measure it at each place, starting with the input to the relay. If you aren't comfortable doing that, find a way to connect the meter while the main power is disconnected and only turn it on long enough to read the meter.
If you suspect the outside switch, try temporarily shorting the pins or better yet pull the wires off the switch terminals and find a way to connect them to each other (with the power off). - wa8yxmExplorer IIIAs I recall Surburans have 2 switches in the 120 volt side and two thermostats (Min and High Temp cut out) and possibly a thermal fuse (do not know on that).
The 120 volt side is independent of the Propane side
Atwood has just one set of thermostats and a control computer.
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 27, 2025
