dad4papa2's avatar
dad4papa2
No 12v power to Motorhome?
Hey folks I have a question about the 12 volt system on my 96 Damon Intruder.
I have shore power and Generator Power and everthing works ok, however when I Unplug and not run the Generator my 12V system does nothing.
I will say that my batteries do need replaced but I set up my Charger and put a good charge on the batteries and still no 12v system working at all.
A few years ago I put an Xantrex converter in place of the old 6300 magnetek and absolutely loved it. Not once did my batteries overcharge and boil them out!!!
Question is When I plug into shore power I used to be able to hear the converter fan kick in when the batteries needed a bit of charge and now I can not get it to kick on at all.
Where do I start??
I have tested all the fuses inside the Mh and all the breakers and they seem to be working fine.
I put a volt meter on what I believe is the wires coming back from the batteries and get a wierd 30v??
On the control board itself should I be able to find a 120v power to the board and then a 12 to 14 volt going to the battery section??
Hope this makes since.
I did check the little disconect switch in the battery compartment and it seems to be fine.
thanks for any input, as I'm now at a loss!!
Dad
