mark1967usaf
May 13, 2014Explorer
No 12VDC
Hello! I have a 1998 Winnebago Chieftain 36WL Diesel Class A. I have no coach power. It worked one day then nothing. I checked my batteries, no voltage. I plug in with shore power, nothing. I disconnected my inverter/converter to install a Dinette. How do I hook up the inverter/converter, not sure what it is. It has a Red and White wire going to my battery. I consider myself mechanically inclined (20 years in the Air Force as a mechanic) but I am stumped. What can I check? What explains the no shore power? If it is the battery disconnect switch, how can I check it? Sorry for the questions..just providing plenty of symptoms :) Thanks so much! Mark
One more thing..If the battery disconnect switch fails, will it eventually drain the coach batteries?
Please help, I really don't want to take it to a dealer!
Once I fix it, I will immediately post what the problem was :)
