ROBERTSUNRUS
May 13, 2022Explorer
RLS7201 wrote:Matt_Colie wrote:
Jay,
You don't say what the chassis but most have the headlights on a separate fuse that is in the fuse group. Now you just have to find it and hope it is bad and that is all that is wrong.
Matt
Headlights are NOT fused. The lead for the headlight switch comes straight from battery power. The headlight switch does have a circuit breaker built in.
The headlight switch does have separate circuitry for the headlights and the parking/running lights. So the switch may be bad, even if the running/dash lights work.
You need to get out your VOM and check for voltage all along the wiring path for the headlights.
Richard
:) Hi, this is the correct answer; Also when you remove the headlight switch, look for a melted connector.
