Edwin_Fox's avatar
Edwin_Fox
no key
I have a 2006 Fleetwood Fiesta lost the keys to the hood anyone know how i might get it open to change locks
  • My newer Fleetwood still uses the 751 key for the hood. if that's the case for yours, probably over half the park has a key that would fit.
  • wa8yxm's avatar
    wa8yxm
    Believe it or not the odds are your Dealer has one.. IN fact, depending on the type of lock *I* might have one.. So might the person next to you in the RV park. (Are you getting the impression there are only a few keys?_)
  • Is this a lock you put on or one Fleetwood put on? If fleetwood walk around the camp ground and see if someone else has a hood lock and try there key if it's like bay door locks all the same key.
  • Take it to or call a mobile locksmith. They can make a key for it in about 10 minutes. Why buy a new lock?
  • Double locks to KEEP folks out from engine area.
    Drive it over to a locksmith or have mobile locksmith come out.
    Might be able to pick lock or drill it out ....they will get it open
  • TucsonJim wrote:
    I'd call a locksmith. They should be able to get it open and change the locks for you.
    HIGHLY recommended. If you can take it to them the cost likely will be less than you think.
    If you absolutely insist on doing it yourself (even though it might cost you more in the end), you probably could drill out the cylinder.
  • I'd call a locksmith. They should be able to get it open and change the locks for you.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
