RJsfishin's avatar
RJsfishin
Noisy Inverter Fan.....Chop a Fan Wire/ No?
A while back I bought a new 300 watt PSW inverter off ebay for a $25 winning bid.
Only problem, fan is noisy, and it runs 100% of the time.
Question, if its designed to run 300 watts in 100 deg temps w/ the fan, whats its chances of running 75 watts in 80 deg temps w/o the fan. I just need some good guesses before chopping a fan wire :))
  • A friend of my brother had a brother had mostly good luck racing railroad trains to the crossing.
    Fans cost five dollars. This is supposed to be a new 300 watt PSW interter
    Why is this even a question?
  • Someone gave me 750W inverter and I used it to power a DirecTV receiver. I clipped the fan wires and lived happily ever after.
    Remove fan, measure size, jump on Tiger, New Egg, Mouser, Digikey, etc, and buy a new one for $10 or less?
  • Car has flat tire -- convert it into a three wheeler?
    With regards to heat...
    This guy said...
    YES I CAN!
  • My GoPower 300w SW inverter will not spin the fan at 75 watt load.
    Worst case you are out $25. If it is any good it should shut down for over temperature but that could take a toll to continue doing that.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
