anon125
Apr 09, 2015Explorer
non exit!
our MH has 2 of these levers that you just rotate and the emergency window opens.
except it doesn't!
with both open and giving it a good push... nothing moves.
any ideas ?
thanks all
westend wrote:
Anything you choose to use on the seals will be better than WD-40. WD-40 eats rubber and certain plastics.
Check the windows every year and lube the seal when you change your smoke alarm batteries.
NOT just any grease...sparkplug boot release silicone from NAPA, made for rubber and will not eat the seal.
fj12ryder wrote:
Maybe just a "good push" isn't enough. Maybe it takes a "really good shove". :)
