- HeisenbergExplorerI would get the element. It is sure to happen again when you are on the road. Cheap insurance.
- duanebowman1ExplorerI got the reefer running I moved the heating element around several times and un plugged the thermistor and no circuit breakers blew. its ice cold and I plugged the thermistor back in so will see if it blows the breakers. still not sure why its working
- robsouthExplorer IILikely a short in the element. Easy fix. Pull one out, unplug the two wires, push in a new one, plug up the two wires. Done.
- The Heat Element is Bad. Doug
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
