_1Flyboy's avatar
_1Flyboy
Norcold N1095 - Freezer-20* | Fridge-Warm
Good morning....Freezer is making ice nicely.....Fridg is not cold enough to keep items from turning bad, but, had been great until this past week ...At 7,000’ on propane.... We have been at this location since 4/18... I’m defrosting the entire unit to see if that helps..Don’t see / smell any ammonia....Suggestions please as I’m unable to drink warm beer!!!......TIA....Adrien
  • 7000' is going to make it work hard. That may be all it can do depending on the ambient temps.
    You might try running it on propane if your not already.
  • ... Coils look good! ...Every thing was wonderful until this week, we have been in same location since 4/18.... Defrosting unit now & we shall see what happens....Any more Suggestions??? TIA
  • Propane flame is NOT hot enough to boil enough ammonia ----freezer section is using up all the available cold ammonia liquid and not enough absorption left to effectively cool food compartment & contents
    Propane flame has to reach up into center of flue opening and transfer enough heat to flue baffle so that boiler section reaches 350*F-370*F to effectively heat the ammonia into a vapor
    High altitude causes an air lean/fuel rich flame which results in cooler temps generated
    Fuel rich conditions create soot which can insulate and resist heat transfer
    Do a thorough clean of burner slots, gas orifice and especially flue/flue baffle
  • If the fins are iced over, THAT is your problem. ICE is NOT a good conductor of cold transfer. The air in the refer has to travel over/thru the evap fins to have the Heat removed. If there is ICE build up, that will cause the refer to not cool. Retest after you defrost give it 24 hours. Doug
  • ...... Defrosted the fridge, banged the flue & coils, blew out flame orifice & the flue.....On electric the fridge is now 40* & dropping..... Will switch to propane when the temperature settles & see what happens...Thanks guys for the suggestions; will give final results when finished.....
  • Over 7000 FT they claim the frig may or may not work on propane, manual tells you to switch to electric. I have found that the temp switch in the flue has something to do with this depending on the way your problem presents. If you reset the frig on propane do you hear the burner try to light, (sounds like a big fart) after 3 times it will quit. If that is the case try jumping the flue switch with a jumper wire across the connection and see if that helps with a reset of the frig. I ended up using a fuse to jumper the two wires to the flue switch which is an overtemp switch to get mine to run in higher altitudes. Good luck!
  • ..... Well the top freezer is working great & the lower fridge seems to be BEER perfect right now ....I also moved some stuff around in the freezer so that the air could circulate in the freezer...We shall see what tomorrow brings & will report further....Again thanks for YOUR help!!!
  • .... Norcoldguy suggested turning unit to coldest setting & then disconnecting the thermistor, which I did... Freezer got down to 7*...Ordered a new thermistor.... Also found out that the fan on the coils in the back of the unit was inoperative; don’t know if it’s from bad fan or bad snap disc; gonna replace the fan with a switch operated fan......Anyhow the N1095 is doing good for now... Thanks to your help & the Norcold Guy!!!
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
