nancyjerry's avatar
nancyjerry
NorCold refrig, no power...
4 door, LRIM 1200 model.
Has worked great with no issues. We did run our generator yesterday because it has been a while. We were plugged in and when generator went off, it did trip the electric off.
But all seemed fine. Then this morning, no power to JUST refrigerator..
Circuit breaker is fine.
  • nancyjerry wrote:
    Looks like an ammonia leak, need new cooling unit...ouch!
    Your rear Recall box did its job---the unit overheated due to the ammonia leak and the recall box shut down power. Doug
  • 2001 Monaco.......so you got 16 yrs of service
    Even with all the off-level operations
  • You could also try a reset by unplugging both the 110 and the 12 volt, let it sit a few minutes and then plug the 12 volt in first, then the 110. We have reset our circuit board that way a couple of times. This is assuming that your black box is not tripped and lit up.
  • Ivylog's avatar
    Ivylog
    Is it on AUTO? if so it should switch to propane if there is not 120V for the electric heater elements. If on auto then go outside and take the vent cover off and see if there is a red light on the black recall box. If on try resetting with a strong magnet run across the box assuming it's a Revision E or higher.
  • RoyB's avatar
    RoyB
    Sometimes the breakers are funny about resetting... Have to really hold down in the OFF position to get it to mechanically engage again. These never get really used since it was installed probably in 2009 when you joined the forum here...
    Along this line and the age of the breaker this one time may have done it in...
    NOTE: Had to read down in your previous posts to find out you have a 2001 Monaco Dynasty Regent 40 ft. Diesel Motor Coach , 2 Slides ...
    Roy Ken
  • It looks like the cut-off switch is lit up. Looks like that is the issue.
    Thank you..
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 22, 2025
