Silas_Carpy
Apr 28, 2022Explorer
Oil change
I’ve read a million posts, am I over thinking this? My sprinter calls for mb 229.51 oil spec. P.o. Used pentosin hp 2 5w-40. It is no longer available in 5w-40. In fact, I can’t find 5w-40 locally, wo...
BurbMan wrote:
The lower viscosities lower internal resistance in the rotating assemblies and help with MPG, but the engine has to be designed to use them. I would call the MB dealer and ask what they use...you can't have the only 2008 Sprinter on the road.
FCA spec'd Pennzoil 0W40 for my 2016 Challenger, and while you could buy Mobil 1 locally in 0W40, Pennzoil brand was the only one that met the FCA specs, so I had to order by the case from Amazon.
I would also keep a couple qts in the rig for topping off on trips since you know you can't buy the stuff locally.
