BFL13
Apr 15, 2021Explorer II
Looks like your converter was not working even before you left. Suspect blown reverse polarity fuses from a mistake when installing the new batteries. Easy to check and fix.
When you isolated the batteries to check them and the "monitor" did not change when you charged the batts, that could mean the monitor is also isolated. You need your own digital multimeter set to voltage to put on the batteries directly.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
