HadEnough's avatar
HadEnough
Onan 2500 LP Generator Acting Up (again)
Hi Everyone,
My Onan 2500 LP generator is starting to show signs of a problem developing but it's a tough one.
I'm wondering if anyone might have some guesses based on experience...
Here is what happens:
When I start it up from cold is starts immediately on the first crank and runs perfectly for about 3-4 seconds.
Then it starts to misfire badly. I almost think it's going to stall. But it doesn't and another minute or so later (I'm in 80+ degree temps), it starts running perfectly and smoothly again.
Has absolutely no problems running loads. No surging, no voltage weirdness, runs perfectly.
Except for about a minute between when it initially starts and when it warms up.
From prior experience, I know to check on this unit any time something starts going funny because it just gets worse and worse otherwise.
Only thing I've done: I took off the sponge filter on that air tube that sticks out of the bottom and cleaned it, then put it back. Nothing else.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
