84jaymini's avatar
84jaymini
onan 4.0 BFA-1R/1600C
I have an older Onan generator--4.0 BFA-1R/1600C.It would not crank so I checked the output side of the start solenoid and was only getting 2.5 volts. I replaced it with a Ford solenoid which appears to be exactly the same. The problem now is that the fuel pump turns on as soon as the battery is connected and it still wont turn over. All wires were hooked up just as I found them on the old one. Any help will be greatly appreciated.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
