dougrainer
Nov 10, 2015Nomad
You will have to have AC control boards that interface with Auto Genset functions. You will also have to run wiring from the AC control boards to the Command 30. Does the Factory have that capability on an ordered unit? Jayco options the Command 30 on both towables and entry level Class-A and Class C models, but they do NOT run the wiring for AC Start. The only Start signal is from a low battery start parameter. You need to go to the Cummins/Onan website and download the Install/Operations manual for the command 30. Doug
