says take to repair shop.any idea how expensive repairs for this might be?should I just look into buying new generator for motorhome? serial #4KYFA26100K
is there any chance the fault code is "14" and not "41" this is a common code (over frequency) and can happen if governor speed is just a little high. also, if field brushes are bouncing on a dirty rotor, this will cause control board to incorrectly read a high speed, as speed is read off of generator stator a.c. signal
