Jan-25-2021 02:29 PM
Jan-28-2021 09:13 AM
Jan-28-2021 08:35 AM
Jan-27-2021 06:32 PM
Jan-27-2021 06:38 AM
Jan-26-2021 08:34 PM
Jan-26-2021 07:41 AM
Jan-26-2021 07:20 AM
jaredmahone wrote:To answer several questions there are much smarter guys here. They often link to a different website. Might be a cummins site. Im sure that link is coming soon.
I'll try the gravity feed tomorrow. Any suggestions if it's surging and sputtering even with a gravity feed? Thank you for the help.
Jan-26-2021 04:41 AM
Jan-25-2021 09:51 PM
Jan-25-2021 05:56 PM
jaredmahone wrote:The section between the fuel pump and the carb is under pressure, not suction. So if the hose clamp and fuel line was not sealing you would be leaking gasoline instead of sucking air.
The fuel line connected to the fuel pump between the carb used to have a proprietary hose clamp but I had to cut it off when I replaced the fuel pump and put an after market clamp that uses screw and it won’t fit down around the fuel pump like the old one. Is it possible I’m getting an air leak there? Could that really be it?
Jan-25-2021 04:35 PM
