HadEnough
Apr 08, 2018Explorer
Only one side of slide moving??
Having another problem with my slide.
This is an Arctic Fox truck camper.
I sheared the main drive pin a year and a half ago, found the problem and fixed it easily. It was accessible.
This time, one of the gears that moves the slide by pushing the toothed track along in either direction just stopped working. I can't see inside the box housing the gear so I don't know what's going on.
When you move the slide in or out, only one side of the slide moves.
I can manually push the lazy side of the slide in or out if I really give it a shove.
How do I go about fixing this?
The gearbox is completely inaccessible when the slide is out.
The gearbox is just about inaccessible when the slide is in. Very very hard to reach.
Ideas? Any experience with one side of a slide failing?
