nieforth
Oct 01, 2013Explorer
parallel 2-2000i honda generators together
Lots of discussion on paralleling 2-2000i Honda generators together using the 120 volt outlets on the unit.Honda generators sold in Canada don't have the parallel plugs installed.some videos on You Tube show using the 120 plugs.A wiring diagram of the generator shows the parallel plugs and the 120 volt plugs are fed from the same source which indicate a plug from each generator tied together should send the output of each gen to increase the wattage to 3??? something watts to run ac for example in RV,s.
any thoughts on this!!!
THANKS Nieforth
EDIT: this appears on Electronics Point site by a Mike Swift.
It appears that you, and several others are right. The wiring schematic
for the EU2000i shows that the two paralleling lines are just single
conductor wires off of the two 120 volt inverter outputs. Their 'kit'
only bypasses the 20 amp circuit breaker used by the U ground
receptacles. With this information I would think that the only
limitation on the number of paralleled generators would be the current
handling capacity of the wiring.
THANKS Nieforth
