Son_of_Norway
Sep 10, 2018Explorer
Parasitic Drain on Solar Power System
Hello. I have 3 100 amp hour AGM batteries in my HR. When I park the RV at storage, I first make sure that they are fully charged, then I connect them to a 50-watt solar panel on the roof to try to keep them charged. However, I have found that the batteries are subject to a parasitic drain of about .6 amp that I haven't been able to eliminate. Hours of sunlight are of course decreasing at this time of year. I am concerned about the parasitic drain. Is there a way to stop the drain by automatically cutting off the current and isolating the batteries when the solar panel stops charging them? What type of device would be required? Thanks for your wisdom.
