red31
May 30, 2013Explorer
Some Coleman folding trailers came with a 16 psi port for their 16 psi Atwood unregulated high pressure stoves, regular Coleman propane stove (15 psi) prior to that. At the cylinder it went thru the high pressure regulator and teed off to the side of the trailer, the other side went on to a low pressure regulator for use inside.
Viking offers 30 psi outside on some pop ups.
CampChef offers a 'RV connection' for use with their low pressure stoves (regulator removed)).
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
