LIKE2BUILD's avatar
LIKE2BUILD
Portable Generator for 50 amp service
I'm preparing to purchase a 5th wheel that has a 50 amp service. We'll be taking a dry-camping trip in August and I need to get a portable generator that will work. For my dry camping we'll mostly be using the A/C, water pump, and a lights. I can keep the fridge and hot water heater on gas operation.
I've had a 30A TT for many years and I've not dealt with 50A systems. Pardon the ignorance but please help me clear up a few things.
1) Does the 50A work on 240volt or 120volt?
2) If 240volt, is it 25A per hot leg?
To get a full 50A service I believe I would need a 6000 Watt generator (50A x 120V= 6000W). Generac has a 6500W (8000W startup) generator that is within my budget. The kicker is to get 6500W it uses the 240V plug that supplies 27.1A to each hot leg.
Will that generator work?
I just want to be sure I don't get burned buying something undersized. Previously I had a Generac GP3250 for my 30A service TT. I thought it was fine since 3250W would give me 27A. It wasn't until after it failed to run my A/C that I realized it was rated for 27A total and delivered 13.5A per leg of the 240V plug and only 13.5A to the 120V outlets. On a cool day that was okay, but in the hot Tennessee sun the A/C kept tripping the breaker each time it tried to kick in.
When not using the generator for dry camping I'll keep it around to backfeed my house in the event of a power outage.
Thanks,
KJ
