jeeperdude10's avatar
jeeperdude10
Power awning seems to be slowing on extending/retracting
Retracted the awning just a few minutes ago, seems it is slowing upon retracting. Have not noticed before, but seemed to be 'working harder' as well. Is there any kind of lubrication protocol to follow or maybe motor is beginning to down hill? 2011 Chateau 31K motorhome. Any and all suggestions are welcome...thanks
  • My Dometic electric awning says to dry-lube the joints every once and a while. I was a wax based teflon spray lube (Dupont I think from Lowes). similar to a chain lube used by motorcyclists.
  • Check your chassis battery. Mine runs off that and if low it effects awning.
  • On mine there is a spring in the end of the tube like on a garage door. It may need adjusting.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
