time2roll's avatar
Jul 30, 2017
Power issues with Frank's Voltage Booster
Voltage in the trailer is moving from 115 to 122 sounds good right? Pedestal is closer to 100+- and Franks booster is in 16 percent boost best I can tell. Trouble is the PI EMS seems to randomly cut power. PE is usually 0 (no issue) or have seen 4 (low voltage). I keep thinking Franks might be swapping between 8 and 16 percent boost and PI cuts power periodically when this happens.
Any other ideas?
Anyone have a PI and booster with similar symptoms?
Having RV issues? Connect with others who have been in your shoes.24,245 PostsLatest Activity: May 11, 2025
