ryankenn's avatar
ryankenn
Power Sag/Current Issues at Seasonal Site
We are in our first year at a seasonal site we think we will be staying at long term. Everything is great, but the power. We only have a small Jayco 16XRB but even its 8K Btu AC and fridge prove challenging.
I haven't had my meter on it yet but you can tell by the sounds of the fans or AC that either the voltage droops badly or the run on the 12 wire from the looks of it is so long current isn't being delivered as fast as its demanded. Depending on neighboring usage fans will start slow and ramp up.
I am looking for ideas on how to combat this? I have setup a solar array at home before, but I don't know what to search for in terms of a device like an MPPT controller, but instead of the panels, that input is line. I would like a bank of batteries to be controlled and charged by the pole 120V (or sagged level its at) and the controller to supplement the supply using the batteries and an inverter so the trailer has steady voltage and good current delivery.
I had hoped a device existed but in searching it may be more practical to just have the site run a charging system that keeps a bank of batteries full and I draw from an inverter.
Thoughts or experience here would be great. The Norcold has already had one control fault leaving us with spoiled food and the neighbour has had some HW boards and the in trailer 12V inverter board fold because of the same issues and I want to avoid this.
Thanks!
Ryan
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
