2cknights's avatar
2cknights
Problem with Generac Generator
I just bought a used Lance 1130. P.O said the generator ran a little rough. I got it home and it starts right up and I turned on the air conditioner to test it and it worked fine. No problems until I turned the AC off. Then the generator accelerated wide open for a few seconds and shut off. I tried this three times with the same result. Any ideas. Thanks in advance for all help. Carey
BTW: This is a Generac NP34 LP. Model 803-4
  • Sounds like there's an issue with the governor or sticky throttle / shut down due to overspeed/voltage. Try lubing up the throttle linkage and see if it helps, otherwise it's most likely not DIY.
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 18, 2025
