Rbertalotto
Nov 25, 2016Explorer
Progressive Dynamics....UGH! (A vent)
I decided that my WF8955 PEC inverter charger wasn't doing what I wanted. I never saw more than 13.7 volts to the battery, no matter what mode it was in.
Research led me to Progressive Dynamics and the PD4655V replacement power unit and replacement circuit board with "Charge Wizard"
I ordered the PD4655 from Amazon and they suggested that I also buy the Remote Pendant. So for an extra $10, I splurged and got the pendant.
The two packages showed up to day and I decoded to install. Just about the easiest modification I've ever made! Only took 20 minutes.
But when I went to hook up the Remote Pendant, there was no where for the telephone type plug on the end of the cord to plug into.
Research found that the pendant I got was for the 9200 series converters. Not the 4600 series.
After about 20 minutes on the internet I see that there is a pendant for the 4600 series but it is no longer available.
So off to the Amazon web site I go to return the wrong pendant.
But before I go, I go back to the Progressive Dynamics web site and after a ton of searching I find a little PDF on how to convert the 9200 series pendant to the 4600 devices....
You'd think they would put this in the installation manual or at least make a bit more noise about it on the web page....(BTW, The installation instructions are terrible, like all PD installation instructions.....They must have hired some executives kid to write them...Terrible!)
But anyways, I got it all installed and the pendant works fine.
Now I can see:
BOOST 14.4V
NORMAL 13.7V
STORAGE 13.2V
And every 21 hours for a period of 15 minutes it will go into DESULFATION MODE
I need to call them on this DESULFATION as I see two terminals that say "WET" or "GEL"....But there is nothing in the instructions on what this is for.
I have AGM batteries and I'm not sure they ever need to go through DESULFATION.....
I'm liking it!
Now I can see:
BOOST 14.4V
NORMAL 13.7V
STORAGE 13.2V
I'm liking it!
