MarkTwain wrote:
Buy 2 new regulators. Buy regulators with easy to read RED/Green window indicators.
Why? He has a dual regulator with two inputs and auto switch over now.
Birdnst wrote:
There is normally a black cap that goes over the top of that dome.
If it was there then you would only see the green at the bottom, then when the tank you are running from goes empty the red would drop down into view.
You are missing a piece, go to your local rv parts store and look at new regulators.
On this point you are correct. This is a Marshall Excelsior MEGR253 regulator and indeed the black cap is missing, which covers all but the bottom 3/8 in of the clear window (I just measured mine).
Marshall Excelsior MEGR 253 regulator at Amazonvalhalla360 wrote:
Which indicator are you talking about?
- The gauge on the tank
- The pop up button on the regulator
I have to assume since he said gauge and noted that the tanks are full but his tank gauge reads something like 1/4, that he is referring to the one on the tank, but yes, he needs to clarify this.
Reference the 2021 Marshall Excelsior RV/Camping catalog (a huge source of information, not just a catalog). See page 6 (8 of 40 in the PDF numbering)
Marshall Excelsior 2021 RV and Camping catalogI apologize if I offended anyone, but Doug is correct on this one.
Charles
