otrfun's avatar
otrfun
Feb 07, 2019
PSW Inverter - No Load Current
Our in-bed camper will only hold two batteries. Wanting to power the microwave, TV, satellite and laptops. Thinking a 2000w PSW inverter would be the right size. Noticed most 2000w inverters have no load current approaching 2 amps. A bit high. Don't want to be constantly turning the inverter off and on during the day to conserve. The Xantrex Prowatt 2000 is the only "2000w" PSW inverter I've found so far with less than 1 amp of no load current. Of course, in reality it's only 1800w continuous with only 3000w surge (typically surge is double the continuous) which may explain the lower no-load. Does the Prowatt 2000 have a good track record powering microwaves? Other 2000w PSW inverters with =< 1a of no load current I may have missed? Thanks.
Having RV issues? Connect with others who have been in your shoes.24,213 PostsLatest Activity: Mar 13, 2025
