navajochief's avatar
navajochief
Pullrite Superglide 18K ISR Unhitching
I started having a problem unhitching my 5er off the hitch. Whenever I'm unhitching, I lower the front landing gear of the trailer and begin to elevate the kingpin off of the hitch. I do it until the capture plate is a barely off the hitch. I then pull the lever and it won't release! I experienced this the last time I took my trailer out. I lubed the tubes and the inside of the hitch too. It looks like the jaw won't release the kingpin. In not releasing the the kingpin, as i raise the trailer the pin remains connected to the hitch and the hitch begins to lift the rear of the truck. I ended up then slamming the truck back and forth while it is locked and eventually it released it. However, I don't remember it giving me this problem when I first unhitched it. I called Pullrite and they told me to chalk the trailer and place the landing gear of trailer to the ground to support the trailer without lifting the weight off of the hitch while the vehicle parking brake is engaged. Once the landing gear is down I am to drive forward with the weight still on the hitch and pull away. He tells me the latch will release. Any ideas? Anybody else having this issue with their pullrite hitches?
4.5" Donahoe Racing Lift, Dick Cepek Fun Country 35" tires, Helo 18" Wheels, Dieselsite Coolant filter with ELC, OEM 4.30 gears, Air lift 5k bags, Pullrite 18K ISR Superglide hitch, 5k HID headlights, Edge CTS monitor.
2016 Keystone Fuzion 325
