BobsYourUncle
Oct 22, 2021Nomad
Another thing I didn't think to mention:
You said it happened after filling and reconnecting the bottles.
There is a safety feature built in to the valve / tank that will restrict or cut off the flow in the event of a sudden change in the flow.
This is to cut off the gas flow if a line gets severed in an accident or something, so that the gas does not flow freely and cause an explosion or fire.
I once activated that safety feature after filling the bottle by turning the valve open very quickly. The solution was to shut it off, disconnect the hose, reconnect and open the valve slowly instead of cranking it quickly.
But that doesn't really explain why other appliances worked.
Just a thought.
Just a thought.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
