Straylight
Jul 25, 2018Explorer
Gotcha--no idea about OEM spec or failure rate for that particular solenoid, personally.
Do you mind if we ask what symptoms you're seeing? A no-crank no-start is different from a cranking no-start, for example; the former doesn't immediately suggest a fuel delivery problem, the latter does suggest a fuel delivery problem.
